GA Aerospace’s Web Site
Date:  3-29-2021
Number of Hours:  3.00
Brief Description:  36iS/U-11
1. The U-00006D-2 and U-00006A-L-2 & -R-2 were temporally assembled.
2. The U-00006A-L-2 & -R-2 were match-drilled. The U-00006D-2 and the U-00006A-L-2 & -R-2 were disassambled and deburred.
3. The U-00006A-L-2 was dimpled.
4. The U-00006D-1 was countersank.
5. The left bracket assembly was made riveting the U-00006D-2 to the U-00006A-L-2.
6. The right bracket assembly was made with the U-00006A-R-2 and the second U-00006D-2.
7. The U-00005A-1, three nutplates and the Left bracket assembly were assembled using three #8 screws on the nutplates.
8. The rivet holes from the left bracket assembly into the U-00005A-1 were match-drilled #40 with an extended bit, then every hole was clecoed .
9. Same steps 7 and 8 for the right bracket assembly.
10. The rivet holes in the U-00005A-1 were countersank.
11. The Left and Right bracket assemblies were riveted to the U-00005A-1
