GA Aerospace’s Web Site
Date:  10-31-2018
Number of Hours:  10.62
Brief Description:  26iS/U-07
10/31/18: 4.6Hrs
1. T-01233 was sanded in order to slide it 1/2in into FLF-00017 with a tight fit.
2. Sealant was placed to the outside of T-01233 and inserted LF-00017.
3. VA-265 was threaded and given its clocking pointing aft.
4. FLF-00017 was threaded into T-01232 making sure it went through the bushing inside of the tank.
5. Sealant was applied to the flange of IE-00001X then attached to the tank assuring its orientation.
6. Sealant was applied to T-1209 and attached to the tank.
7. Sealant was applied to the flange of IE-385B and attached to the tank.
10/31/18: 6.02Hrs
The tank was cleaned.
Section 26 was documented.
