GA Aerospace’s Web Site
Date:  2-3-2021
Number of Hours:  0.10
Brief Description:  PAP G4-1
Section G4 - Engine Check
The cowling upper and lower was removed, the engine was properly attached.
Throttle control. was properly attached and can operate full range. The eco stop is set al 98%
Cabin heat control: properly attached.
Each heat door had a proper operation from fully opened to fully closed. each heat door rests against its seat when the heater control knob is fully closed.
The cooling system was filled in accordance with Rotax SI-912-016 latest revision. the radiator was filled to fill plug height before tightening and safetying the plug.
Oil system was filled in accordance with Rotax SI-912-018 (latest revision) procedure.
Added approximately 4 gallons of fuel to the tank and there were no leaks.
