OTHER APPROPRIATE SYSTEMS: The canopy was latched. Canopy warning is shown on EFIS.
LANDING GEAR & BRAKES: The gear access covers were removed. The gear attach nuts are properly torqued. Brake system has been filled with a MIL-H-5606 equivalent (MIL-PRF-83282) The brakes on the pilot seat were pressed and held for 30 seconds and feel firm. No leaks on brake lines. The aircraft was pushed while holding the brakes and it was confirmed that it does not move when pressing them Brake pedals on passenger seat were tested as it was done on the pilot's seat. It passed all tests. No leaks were found. All tires were pressure checked (25psi on main wheels and 22psi on landing wheel). There is enough gap between the tires and fairings.
