1. Clear silicone adhesive was applied to the lower end of the F-00059B 2. The F-00059B was attached to the F-1202H-L Repeat 1-2 for the right side of the fuselage. 3. The foam seals and silicone cured in 48 hours 4. Positioned a 1/16 spacer roughly tangent to the F-01240-1 The upper end of the F-00059B was trimmed. The outboard end of the F-00059A-L & -R was trimmed 5. Seal adhesive cured, the canopy was closed and the foam was marked adjacent to the bottom of the 0.125 in thick aluminium plate.
