1. The underside of the fiberglass lay-up was inspected. 2. The surface was cleaned with rubbing alcohol where thefwd is sopposed to be attached. 3. The cut length of the seal was measured 4. Approximately 12 in of paper backing from the adhesive strip were removed 5. The seal was positioned 6. The next 12 in were also removed. 7. Firm pressure was applied.
