1.With the canopy closed and latched slided the foam spacer into the gap between the WD-1219 and F-01234-L-1 2. The entire length was cleaned. 4.. The starting point (fwd end) of the C-1217B was determined by transfering the mark made to the outer surface of the C-1202, then to the inner surface of the skirt and to the bottom of the square tube, 5. The C-1217B and C-1217C were fabricated. C-1217B was attached The adhesive leg where it butts to the weld at the corner of the tube was trimmed. The non adhesive leg at the angle at the corner was trimmed. 6. Repeat step 5 for the C-1217C. 7. steps 4-6 repeated fot the other side.
