GA Aerospace’s Web Site
Date:  5-14-2020
Number of Hours:  0.10
Brief Description:  39iS/U-17
1. A trim line was draw to the surface of the cured fiberglass.
2. A 3/8 hole was drilled through the glass fabric lay-up at the location of the canopy pivot bolt centers.
3. Re- drilled the 3 holes on both sides and reinstalled the screws, washers and nuts.
4. The Canopy lay-up trim template was cut out, With masking tape the template was aligned to the canopy
5. The struds were re-installed and placed the canopy back on the fuselage. Pivot bolts were installed.
6. Brush-coated with epoxy the areas of the C-1208
