The 25-pin d-sub labeled “HIC” on the Common Harnesses was disconnected from the AV-60009 HIC Connector Module.
The backshell was removed and Pin 14 and Pin 15 located.. Using the extraction tool was removed the WHT/BLU and WHT wires and their pins from the Pin 14 and Pin 15 locations in the 25-pin d-sub connector. The WHT wire and pin was inserted into the Pin 14 position and the WHT/BLU wire and pin was inserted into the Pin 15 position. The backshell was reinstalled and the 25-pin d-sub was reconnected to the HIC Connector Module.
