5: The internal battery (Duracell 28L 2CR11108, with expiration date 03/03/30) was installed in the E-04.5 Cockpit remote.
08/12/20 5.1Hrs 1: NA 3: The AV-60007 Ignition module was attached to the F-00043-1. 4: The switch and ES-807039-1 Gasket were attached into the F-00043-1.
6: Small notches were made in the stiffener of the F-00043-1 Panel (To the bottom screws holes on the side of the nut) to allow installing the E-04.5. Then the E-04.5 was installed to F-00043-1 Panel.
08/18/20 1.5Hrs 2: 19 holes of the F-00144 were countersunk and then prime and paint were applied to them.
