03/25/20: 4.48Hrs 1 Completed. The main harness wires were secured to the clamps on F-01230-1
03/04/20: 0.5Hrs Worked on step 2 by deburring the four F-01212A brackets.
03/05/20: 3.62Hrs 2: The wire routing brackets were riveted to F-01212L & R and the wires were inserted into their slots. 03/12/20: 0Hrs 3: After routing the WH-P30 cable forward and through the routing brackets, the last snap bushing was installed on F-12103 completing this step.
4: The audio alert cable was connected to the remote. 6: F-12123B was glued to F-12123A.
03/17/20: 0.22Hrs 7: The 10 spare fuses required by the POH were installed in F-12123A. 8: F-12123B was glued to the bottom of F-01202B-1 along with F-12123A.
