02/27/20: 2Hrs 1: NA 2: The GPS and XM cables were routed through the firewall. 3: The cover plate and grommets were installed onto the firewall. 4: The GPS and XM cables were roughly positioned where they should be connected.
08/11/20 1.10Hrs
5: The GPS and XM Antenna, EarthX were secured to the ROTAX ECU cables with tie grap 6: the spade terminal was connected to the spade terminal on the wire fron ES-ETX900. 7: Tank sealant was aplied to grommets around the cables and wire.
