GA Aerospace’s Web Site
Date:  2-21-2020
Number of Hours:  4.84
Brief Description:  38iS/U-06
02/19/20: 0.5Hrs
The 1/16" spacers for step 1 were created.
02/20/20: 1.67Hrs
1: The previously created spacers were inserted between WD-01214 and WD-1215.
2: Both WD-01214 were pushed outboard until they were firmly against the spacers between them and A-1207. The parts were clamped together.
3: Adjustments were made to the pushrods in order to get the same distance between both bolts and F-01206F-2.
4: The two holes on each WD-1215 were used to match-drill #30 both WD-01214.
02/21/20: 2.67Hrs
5: Both WD-01214 and both WD-1215 were removed from the fuselage.
6: The two wings were removed from the fuselage
7: WD-01214 and WD-1215 were clecoed and clamped together
8: The two bottom holes on the bottom of WD-1215 were used to match-drill #30 both WD-01214.
9: The previously match-drilled holes on WD-01214 and WD-1215 were final-drilled #12.
10: Both WD-1215 were reinstalled.
