GA Aerospace’s Web Site
RV-12iS B
49iS-02
10/30/19 6.7Hrs
Step 1: Nutplates were riveted along the sides of the F-01246S. The holes rivets were not dimpled because they were already dimpled.
Step 2: NA
Step 3: Nutplates and F-01246E were riveted on F-01246S web. The F-1246A was already riveted.
10/31/19 4.10Hrs
Step 4: The hole on the F-12134 was countersunk #27. The screw, nuts and the spring were assembled as required.
Step 5: The two MS20151L08 were riveted together.
The slot in the F-12134 was filed so the screws move freely.
Step 6 : The spring end was attached to the F-0146E and the whole Eco Stop Assembly was put in place.
RV-12iS B Home
3643
.Avionics
.Empennage
55
331
.Finish
96
569
.Fuselage
115
758
.Inventory
.PAP
.Powerplant
.Service Bulletin
.Wings
Batteries Log
ECU Cycles log
Painting process
PAP
Powerplant
RV-12iS A Home
