10/30/19 0.90Hrs 2: A #19 hole was drilled on the F-1232A.
03/04/20: 2.47Hrs 1: An ES E22-50K was modified by cutting the roller off it. 3: F6035 was connected to the COM spade of the switch. 4: F6035 was secured onto F-1232A 5 & 6: The canopy latch switch was loosely mounted to F-01231F-2. 10: ES-00301 was position to match-drill it into place, then it was riveted to F-01203A-1.
11/12/20 .6Hrs 7: The canopy latch sensor was pivot towards the WD-01218-1 until it maked contact and heard a click.
8: The fastener of the Canopy Latch Swich were tight.
9: The operation of the Canopy latch switch was checked several times
