6/24/2019 1.25Hrs Step 1. Each C-1212 was mesaured, marked and drilled. Step 2. The edges of each C-1212 were radiused Step 3. Two holes were countersuk on each C-1212 to fit a #8 head fllush screw
04/12/2020 0.7 hrs Step 4. The canopy was unlatched and rotated to open position.
04/13/2020 2.6Hrs Steps 5. Each guide block were rotated on its screw until the lower outboard corner is tangent to the outside surface of the roll bar frames. 6. The canopy was rotated down to closed position , there was no interference between any screws.
