Brief Description: *** 11iS/U-03 Pending Final Assembly
03/14/19: 1.16Hrs Step 2 completed
Step 3: The WD-1223 counterbalance arm was inserted into the stabilator assembly.The counterbalance weights were inserted through the hole in the aft bulkhead of the tailcone assembly.
Step 4: The stabilator assembly was installed to the Tailcone assembly using the indicated hardware.
Step 5: The stabilator assembly movement was correctly checked.
