Step 1, The VS-1204 was removed. 2. A piece of paper was put on top of the aft end of the tailcom assembly. 3. The rear spar was attached to the tailcome assembly ussing the lower four fasteners 5. The Rudder assembly was temporally installed to the V-Stab assembly.
03/13/19: 1Hr worked on step 7
03/14/19: 3.75Hrs Step 4: The step was correctly developed, but the lower hinge assembly will be added in the final V-stab assembly. step6, ,8(NA) completed. On step 6, it was noticed that the rudder was contacting the v stabilizer's skin, Van's advice was beveling the V. Stab's skin 7. The attached hole o the R-1014 were final-drilled #12
