02/21/19: 4Hrs 1. The scribe lines on the COWL 12 iS TOP & BOTTOM were traced with a fine point permanent marker. 2. The upper edge of the bottom cowl was marked 4'' from the forward corner scribe lines on the left and right sides. 3. The edges of the top and bottom cowl were sanded. 4. Step 4 was correctly performed. 5. High and low spots Along the inner surfaces of both top and bottom cowls were smooth sanded.
11/04/19 7.03 Hrs Worked on step 6.
11/05/19 0.90Hrs Step 6 completed: The mating surfaces of the top and bottom cowls were cleaned and sharpened so the area around the corner fit.
