GA Aerospace’s Web Site
Date:  1-14-2019
Number of Hours:  5.66
Brief Description:  09iS/U-08
01/11/19: 4Hrs
1. HS-1215 was clecoed to the main skins.
2. Two #52 holes were match-drilled into the main skins using the splice plate (HS-1215)
3,4 . HS-1218A-L&R were riveted to the skins and to HS-1206 and HS-1216.
5. The remaining holes on the skins were riveted.
6. HS-1217 were separated.
7. Both HS-1217 were pinched a bit to make sure they laid flat onto HS-1208.
01/14/19: 1.66Hrs
8. A total of 4 #30 holes per rib were match-drilled into them using HS-1217.
9. Both HS-1217 were riveted to both HS-1208.
