01/11/19: 1.33Hrs 1. The left and right side static sources were installed into the F-1280-L &-R 2. Two PT 1/8 CLR PLASTIC of 24 inches long were cut to make two F-00012.
01/14/19: 1.67Hrs 3. The end of one of the F-00012 was intalled over the right static source and one on the end of the other static line port. 4. PT 1/4 OD tube of 15 inches long esd cut to make the F-00013. 5. PT 1/8 CLR PLASTIC of 7/16 inches long was cut to make the F-00014 11/01/19 1.35Hrs 6.The left static source was placed. The joint between the right line port-tees was sealed with RTV Silicone.
11/02/19 0.89Hrs
7. The right static source was placed. The joint between the right line port-tees was sealed with RTV Silicone.
