01/08/19: 2.91Hrs 1. The edges of all of the HS-1204 were filed to create a radius, a coin was used to mark the radius desired. Step 2 was worked on.
01/09/19: 1.67Hrs 2. HS-1216 ribs and HS-1206 ribs were riveted to the rib clips. 3. HS-1204 forward ribs were riveted to the front spar and to the HS-1206 ribs. 4. The ribs step 4 calls for were replaced as the note says for HS-1204 on the forward spar and HS-1206 for the aft spar because we are installing the optional fairing tips.
