10/05/18: 1.5Hrs 7. F-1232B was separated. 8. F-01254 L&R were separated. 9. Two holes on each of the F-01254 were drilled #17, and dimpled #8. 10. The three holes on the forward end of both F-01254 were dimpled #30 11. F-01254A was separated.
10/09/18: 1Hrs 12.The top edge of both F01254A was slightly broken. 13.Both F-01254A were riveted to its respective side of F-01254.
10/11/18: 2.5Hrs 1-3The hole on C-01205A was match-drilled into the roll bar assembly as noted in the manual, it was deburred afterwards. 4. The three holes on the roll bar assembly were tapped #8-32. 5. A rivet was installed as noted on the roll bar assembly.
02/18/20: 0.07Hrs 6.C-01205-2 was installed onto the roll bar.
