42MiS/U-23: The fuel sender and ground wires were roued and crimped.
42MiS/U-24: The fuel sender wires were wrapped to the ES-00301 that is beneath the baggage area. The GTR antenna cable was routed but not connected to the antenna because the antenna will be installed after painting. Another ES-00301 was installed on F-01206H-L. The fuel pump power cables and fuel pressure sensor were routed aft and connected.
42MiS/U-25: The ADHRS cable was roued aft, along the stiffeners and wrapped to the F-1208 frame.
42MiS/U-28 The wires on the harness were routed through the plastic clamps. The F-01212A brackets were riveted to the fuselage. We worked on step 3 by installing the bushings.
