42MiS/U-13: Step 7 was completed but the D sub connector on the IS CAN BUS Connector was replaced and then installed onto F-01202B-1.
42MiS/U-19: The headset jacks were installed onto F-1226 on both sides. Continuity was tested between the nuts and the fuselage. ES-00301 were installed to the fuselage on both sides. The terminals for the pilot stick were grounded to the fuselage.
42MiS/U-21: All wires were tie-wrapped to their respective brackets. The USB dual panel was installed along with the F-12101 and the wires were connected to it.
42MiS/U-23: Steps 1 through 4 were completed. In order to route the wires through the bushing, their labels were removed, routed, then installed again.
