39iS/U-20: Foam seal C-1219 was attempted to fit into the gap between the canopy frame and the canopy deck, luckily it did not. The underside of the canopy frame was cleaned in order to install the C-1217B and C-1217C seals on both sides as instructed on steps 5 and 6.
39iS/U-21 Instead of having high spots in the fiberglass we had low spots, a call to vans confirmed that this should not affect the seal between the parts. The surface was cleaned and the SEAL-00001 was installed with the flap pointing forward. The seal was pressed against the surface reinforce adhesion but it still needs to be checked later.
39iS/U-22 The surfaces were cleaned. Silicone was applied to both F-00059A-L&R and were installed to their respective sides.
