Note: the oil used on step 9 was not a good option because the pieces were stuck together and then the resin was on Nose Leg Assembly so we had to remove all the mixture and repeat step 9 but now we used grease (NOT OIL) repeat the step 10 and wait for the epoxy flox mixture cure again.
