Brief Description: Sec 32, Pages 32iS/U-09 and Page 32iS/U-10
Flight Controls **Page 32iS/U-09** these steps were completed:
5. The manual says that 28 holes should be riveted but there are only 24 on the part.
7. Is easier to place the manufactured head of all rivets on the forward side. A wedge was needed.
Steps 8 and 9 could not be completed today, on step 8 you have to tap the pushrod, we tried this on a bench vise with padding. Even with padding, the pushrod was able to rotate and it got damaged. We would advise to use something that protects even more and grips better without too much force
On**Page 32iS/U-10**:
1. N/A
2. In our case this was not necessary, the original length of the bushings was perfect for this purpose.
3. We used a belt sander to remove the material and sandpaper to remove the loose powder coating. Check the picture for a reference of how much the bearing should be protruding.
