Brief Description: Sec 32, Page 32iS/U-03 and Page 32iS/U-07
Flight Controls -
On **Page 32iS/U-03** we completed the following steps, completing the page (Before doing step 6, check step 7):
6. All manufactured heads should be on the bulkhead, it is way easier. A wedge was needed for some holes.
7. This is pretty hard. Make sure that the bolts fit through all holes with no problem, if they don’t, you should take the control column out and match drill the holes with the respective bit.
On **Page 32iS/U-07** we completed these steps and the page: 1. N/A
2. If in doubt on where to place the manufactured rivet heads, check the pictures. We believe it doesn’t affect but it looks better.
