47iS/U-09: Tool-00002 and the iPhone previously zeroed with the canopy deck were used to pitch the propeller blades. Several readings were taken until the angle hit 71.2 degrees. with a variation to 71.1, this was done for both propellers in order to assure the angle difference was not bigger than .1 degrees. After torquing the bolts, the pitch was re-checked.
47iS/U-10: The spinner and the spark plugs were reinstalled.
