42MiS/U-27: The 30" plastic tube was created and routed along with the cables into the roll bar. The spade terminal on the canopy switch wire was crimped and connected to the switch.
40iS/U-11: Steps 1 through 5 had been already completed previously. The cables on the cockpit light were crimped to the butt splice and then the light was riveted to the light bracket. The harness wires were crimped to the butt splice as well.
42MiS/U-28: The velcro was adhered to the fuse holder, the 10 spare fuses were inserted and the holder was installed below the panel.
42CiS/U-09: F-00062 was riveted to the tailcone.
42CiS/U-10: The ADAHRS was attached to the brackets, the d-sub was connected and the lines (AOA, static and pitot) were connected to the FLF-0007s installed in it.
