42MiS/U-10: The canopy latch switch was mounted to F-01231F-2, the canopy was closed and the switch was adjusted so it is activated when the latch is in position.
The grommets from pages 42MiS/U-14 & 15 were filled with proseal.
42MiS/U-19: The pilot stick connectors on both sides were connected to their respective harness connectors.
42MiS/U-26: The harness was routed as instructed, the wires were routed but the step was not completed since the antenna is not in place yet. The spade terminal was crimped onto W6075 and connected to the NC on the pin switch.
42CiS/U-09: The 10th rivet was removed, the F-00062 was clecoed to the tailcone and used to match-drill a total of 10 holes #30.
42CiS/U-10: The three FLF-00007 were installed into the SV-ADAHRS-200.
