GA Aerospace’s Web Site
Date:  5-23-2019
Number of Hours:  8.50
Brief Description:  42MiS/U-23, 42MiS/U-24, 42MiS/U-25, 42MiS/U-28
42MiS/U-23:
The fuel sender and ground wires were roued and crimped.
42MiS/U-24:
The fuel sender wires were wrapped to the ES-00301 that is beneath the baggage area.
The GTR antenna cable was routed but not connected to the antenna because the antenna will be installed after painting.
Another ES-00301 was installed on F-01206H-L.
The fuel pump power cables and fuel pressure sensor were routed aft and connected.
42MiS/U-25:
The ADHRS cable was roued aft, along the stiffeners and wrapped to the F-1208 frame.
42MiS/U-28
The wires on the harness were routed through the plastic clamps.
The F-01212A brackets were riveted to the fuselage.
We worked on step 3 by installing the bushings.
