GA Aerospace’s Web Site
Date:  5-22-2019
Number of Hours:  7.50
Brief Description:  42MiS/U-13, 42MiS/U-19, 42MiS/U-21, 42MiS/U-23
42MiS/U-13:
Step 7 was completed but the D sub connector on the IS CAN BUS Connector was replaced and then installed onto F-01202B-1.
42MiS/U-19:
The headset jacks were installed onto F-1226 on both sides.
Continuity was tested between the nuts and the fuselage.
ES-00301 were installed to the fuselage on both sides.
The terminals for the pilot stick were grounded to the fuselage.
42MiS/U-21:
All wires were tie-wrapped to their respective brackets.
The USB dual panel was installed along with the F-12101 and the wires were connected to it.
42MiS/U-23:
Steps 1 through 4 were completed. In order to route the wires through the bushing, their labels were removed, routed, then installed again.
