GA Aerospace’s Web Site
Date: 3-10-2018
Number of Hours: 24.00
Brief Description: Pag 21 iS/ U-02
Team: Eduardo Duran, Andrea Limon, Magdalena Rios, Alma Elguezabal
Abscent:0
We continue with step 4 on page 21iS / U-02, perform dimple # 30 on parts F-01224-L-1 and R-1 indicated in figure 2 and after dimple # 40 on both parts, taking care to do so in the correct hole (the die of the dimple we cut it from one side so that the pre-folded surfaces of the pieces will not be damaged).
Step 5 (21iS / U-02): the protective plastic was removed with a soldering iron, clecos were placed too, after placed the nutplates K1000-08D in the holes of the pieces F-01224-L-1 and R-1 and placed the corresponding rivets AN426AD3-3
Step 2 (21iS / U-03): it was made dimple # 30 in the holes of the pieces F-01221 corresponding to the dimple of the holes of the piece F-012224-R-1 according to figure two of this page. Then cover with tape the holes of the pieces F-01241 (plastic bar) F-01224-R-1 and the luggage ribs.
Step 1 (21iS / -04): We machine countersink #30 to 2 pieces F-1206D of the 4 that there is, only where indicated in the figure of this page, after two pieces were deburred, one already with countersink and the other not,for later riveting with a COM-3-5 bearing in the middle and with rivets AN426AD4-7.
Step 4 (21iS / -04): We perform dimple # 30 and # 40 in the holes of the pieces F-01206H-L- and R- as indicated by the holes of the pieces F-01224-L-1 and R-1 The team makes different steps in different pages to be able to advance, since we are two fuselage teams and some pieces are occupied by the other team.
Clecos nut plates
Big Riveter C
dimpling
