Brief Description: HS and small amount of fuselage work
I have been working on the HS, and the many small brackets that are used when I actually attach it to the fuselage. Just a few hours each day and then more on Sunday. Also, drilled the lower hole for connecting the main pushrod to the elevator. Once I get it attached I will then be attaching the VS, rudder and the rudder stops.
