Brief Description: Attachment work bearing to rear spar HS
Bolted the ctr bearing on the aft spar HS today. Prior to today it was only clecoed inplace. I'm just about ready to drill the all important hole in the elevator control arm for the attachment to the bearing. I need to get a 1/4" tube, sevices as a guide, to fit through the center bearing and drill each elevator separately. I will start with the right elevator first and then do the left.
