-REMOVED 2x RIVETS ON LH SPAR I ACCIDENTALY INSTALLED WHERE RIB GOES -CLECOED & MATCH DRILLED NOSE RIBS TO SPARS -CLECOED & MATCH DRILLED MAIN RIBS TO SPARS ***LH AILERON ONLY*** -CLECOED SKINS ON & MATCH DRILLED/OPENED IP LWR SPAR HOLES TO #30 -REMOVED TRAILING EDGE & DRILLED NOSE RIBS TO BALANCE WEIGHT -DISSASSEMBLED, DEBURRED & DIMPLED LHS PARTS -RIVETED NOSE RIBS TO WEIGHT -RIVETED LE RIBS TO LE SKIN -REALISED I WASN'T SUPPOSED TO RIVET LE RIBS TO SKIN YET, SO REMOVED 4 RIVETS FROM LE SKIN-RIB TO ALLOW RIVETING ACCESS -RIVETED LE RIBS TO SPAR -STARTED RIVETING LE/TE SKINS TO UPPER EDGE OF SPAR
PICTURES- 2016113 RIVETS - INST 24 - REM 6 WING RIVETS - INST 1795 - REM 41 TOTAL PROJECT RIVETS - INST 4112 - REM 92
