-FOLDED TRAILING EDGES TO FINAL BEND -CUT 408 REINFORCEMENT BRACKETS OUT OF SUPPLIED .040" MATERIAL -MATCH DRILLED REINFORCEMENT BRACKETS & AILERON ATTACH BRACKETS TO SPAR -DEBURRED, COUNTERSUNK & PRIMED 408 REINFORCEMENT BRACKETS -RIVETED 408 REINFORCEMENT BRACKETS TO SPARS & NUTPLATE TO LH ASSY ONLY AS I'M MISSING ONE OF MY NUTPPLATES. ***ACCIDENTALY INSTALLED 426 RIVETS IN LH IB SIDE WHERE IT SHOULD GO THROUGH MAIN RIB, SO I'LL HAVE TO REMOVE 2 OF THOSE LATER ***LEFT 1/8" CLECOS AT HOME SO CAN'T PROGRESS ASSEMBLY ANY MORE
PICTURES- 20161108_203254, 203302 RIVETS - INST 16 - REM 0 WING RIVETS - INST 1771 - REM 35 TOTAL PROJECT RIVETS - INST 4088 - REM 86
