-BOLTED LAST Z BRACKET TO SPAR -STRAPPED FUEL TANK ASSY TO WING -DRILLED JOINT PLATE TO #19 -DRILLED INBOARD RIB TO Z BRACKET -REMOVED OUTBOARD LEADING EDGE -DRILLED OUTBOARD RIB TO Z BRACKET -REMOVED SKIN AND INTERIOR RIBS OF FUEL TANK -DRILLED ALL OF BAFFLE TO Z BRACKETS
PICTURES- 1156-1161 RIVETS - INST 0 - REM 0 WING RIVETS - INST 407 - REM 8 TOTAL PROJECT RIVETS - INST 2622 - REM 53
