-Continued deburring of right flap -Found a fair bit of light surface corrosion on skin edges and around holes -Removed corrosion -Dimpled as required Primed with P99 wash primer i'm trying out, didn't come out as well as I had hoped with a fair bit of running but by the end got it figured out and hopefully I can do better next time -Run out of time to work on the other side
