Patrick Kelley (Flion)
Date:  6-17-2011
Brief Description:  Match-drilled bottom skins and left fuel tank baff
Had other stuff to do today so I couldn't spend much time with the project. No pictures; the match-drilled parts clecoed together don't look any different. I match drilled the fuselage bottom skins where they mate with the spar center section and also the side pieces. Then, since I was on a roll, I also match-drilled the left fuel tank baffle to the fuel tank skin (the ribs-to-skin and ribs-to-baffle was already completed). Now to pull everything apart, do a lot of finishing (deburr, dimple, countersink, ...) and prut it back together.
