Replaced the old UMA backup altimeter with a two-hand, 20' sensitive altimeter from West. Also replaced the burnt-out lamp in the boost pump switch with an LED replacement that is much brighter than the other lamps. I'll keep the other switches as-is until/if the lamps fail.
