Patrick Kelley (Flion)
Date:  10-19-2008
Brief Description:  fixed oil leak, other troubleshooting
With assistance from Myron James, I retorqued the oil filler and resaftied it. I also checked out the wires from the Lightspeed ignition for RPM indication. A test runup allowed Myron to locate the oil leak at the oil pressure sender line at the engine. This was torqued and no further oil leakage was noted. The RPM sensor continued to malfunction. I also noted some problem with idle and difficulty shutting the engine down using the mixture control. These will be addressed in future sessions.
