Patrick Kelley (Flion)
Date:  7-17-2008
Number of Hours:  6.00
Brief Description:  Firewall shields, hobbs wiring, canopy latch
Installed the nutplates for the 6 firewall shields using 3/4" grommets. Sealed nutplate rivets with RTV. Wired the hobbs pressure switch to panel and ground. Fitted and installed the canopy latches. They are a little tight and will need to be adjusted.
