Brief Description: pressure sender installation, tank sender, right f
Installed the pressure senders to final position and torqued hose connections. Oil sender has a "T" fiting that has an attached pressure switch for the hobbs circuit. Wiring of switch and senders not completed. Made final firewall penetration for lower ignition wires and began drilling for the screws for the shields at all the penetrations. Also cleaned up the last of the interior runs of wiring: autopilot cables, ELT cable, and AP power. Installed scat tubing to NACA vents with hose clamp.
Used epoxy and flox to reinforce fiberglass repair on flap. When set, installed flap linkage and adjusted to be equal to the left flap. Performed preliminary sanding of repair.
At the EAA Chapter meeting, installed the left fuel tank sender and end plate. Then installed a balloon and pump for pressure test and inflated the tank for overnight test.
