Patrick Kelley (Flion)
Date:  6-24-2008
Number of Hours:  6.00
Brief Description:  Fabbed center column, cabin heat controls.
Fabricated screw attachments for the center column, determined control spacing, and drilled holes to accept controls. Painted and installed the center column. Used prop cable to measure for throttle and mixture cables. Routed and installed bowden cable for cabin heat to panel at top and just right of radio stack.
Recieved prop from Hartzell today, unpacked in shop and took manual home to read.
