Patrick Kelley (Flion)
Date:  6-18-2008
Brief Description:  Pitot hookup
Removed left wing root fairing, checked fluid connections. Checked aft spar bolt tight and has cotter pin emplaced. Checked wing tank attach and safety wire. Hooked up final pitot connection and cleaned up run, then ops checked with airspeed on EFIS and mechanical backup. Also cross checked altimeter on mechanical backup, EFIS, and Garmin GTX-327 transponder.
