Installed feed and return lines for oil cooler. Installed "T" fitting on outupt of mechanical fuel pump and installed line from output to fuel servo. Installed line from fuel servo to fuel distribution block. Installed line from firewall to mechanical fuel pump on fuel pump, determined firewall location and requirement for 45 degree bulkhead fitting (fitting ordered). Removed prop oil line at forward fitting to determine penetration location through baffling.
