Brief Description: Found and Corrected the Verticle Stabilizer Twist
Started at 1:00pm and Stopped at 4:00pm
While trying to fit the rudder to the Vertical Stabilizer I noticed the verticle stabilizer was twisted at the top. I then checked the rudder to see if it was twisted and it was. The process to fix the problem was to remove the glue joints until the twist left the part. Removed the rear spar from the verticle stabilizer and then cut the front spar of the verticle stabilizer down the middle. Cut the seam of the verticle stabilizer from the top down the front about half way. The verticle stabilizer had now lost its twist and was back to normal.
